v12 PERSPECTIVE
    • January 23, 2020 at 12:43 pm #265404
      Carl S.
      Hello,
      In using V12 perspective mode is there either a way to make Hidden View the default mode when viewing in perspective? Or is there a way to keep it in hidden mode once you make the change. It seams to always default back to a rendered color mode.
    • January 23, 2020 at 3:21 pm #265406
      Hi Carl,
      If you go into your 2020 preferences under the “rendering performance” tab you will see a box called “rendering”. Click on the drop down menu “mode”. You can then choose your desired rendering default.
