July 27, 2020 at 3:51 pm #291196Alan McCormickParticipant
Can anyone help, I m struggling to find a catalogue/range that has a true handle-less kitchens.
I have the Tkc catalogue but it doesn’t apply the aluminium profile.
Thanks Alan
July 27, 2020 at 4:21 pm #291201zubair halimParticipant
Hi Alan
I had the same problem with the TKC files while back when having discussion with Fusion support team.
Any way You need to select a file or design which is VERO Rail well this is what they TKC call it. when ever you select larders it will ask for if you want to add the Rail you select it and it will add. And also the base unit need to select with rail already onit.
And Also main important If you selecting catalogue JIGSAW then it will work or Selecting Component it wont add unless you spend a lot of time adding your self.
TKC are more closer with articad so they support them more then us for some reason. BUT 2020 Fusion is one of the best in comparison.
July 27, 2020 at 5:31 pm #291215Alan McCormickParticipant
Hi Ken
Sounds great, I might borrow that one. I’m currently building an anthracite and copper but its the design side I was finding difficult to find on 2020 but got it now in the tkc jigsaw catalogue
Cheers Alan
July 27, 2020 at 5:36 pm #291216Alan McCormickParticipant
Hi Zubair
That works!!!!
Thats saved me a few hours … phew
Many thanks
July 27, 2020 at 5:40 pm #291217zubair halimParticipant
Hello,
Great to here that sorted and yes I am working on exactly same anthracite with copper,
See link below
