Applies to: 2020 Worksheet
Using the 2020 Report Designer, it is easy to add an image or logo to a report. After you have generated your report, choose “Edit Report Design…” From your Reports menu.
This will launch the 2020 Report Designer allowing you to make changes to the report template.
From the Field Explorer, under the Reusable Fields Section, is an option for Image. Simply drag and drop the Image from the Field Explorer to the position in the report template you wish the image to appear. The Report or Page Header is the most common area to include a logo or image.
Double click on the Image Not Found place holder to select the image you wish to use. Click the … button on the Image Location line to select your image file and then press OK. You will then see the image added to the report template.
If you need to adjust the position of the image simply click and drag the image. To resize the image, left click the image and use the green grips to shrink or expand the size. You can also select the image and press the delete key if you wish to remove the image from the report.
Remember to click Save in the report designer to save your changes. You may now return to the Worksheet and refresh the report to see any changes you performed in the report designer
