September 20, 2018 at 4:00 pm #204815
ParticipantI tried to search for this issue – but my searches keep bringing up issues with Microsoft Windows – LOL!
Suddenly – out of nowhere, all the windows I drop into this design don’t cut through the wall – the wall goes through them. They are like a picture frame hanging on the wall with no picture.
Did I click some setting somewhere?
Doesn’t seem to matter what window I use. When I look at the Attribute for the window, the glass and the scenery are there… I’ve In/Out adjusted. I’ve deleted the windows and put in new ones. I turned off the placement zone and turned it back on. These are standard catalogue windows – I am not using the Wizard.
Any ideas?
September 20, 2018 at 7:58 pm #204841
Mike Langensiepen
Pilot ProThis happens occasionally and I have found no fix apart from using the control key or the in/out variable to force them into position. The only other fix is to start a new drawing, drawer the walls again and add the windows and doors and then copy and paste everything OTHER than the windows and doors from the original drawing.
September 21, 2018 at 10:00 am #204844
ParticipantThanks, Mike! I even drew a new wall elsewhere on the floorplan and put a window in it just to test. Same thing.
I did end up grabbing the entire kitchen, lights, everything except the walls and copy/pasting onto an entirely new kit file.
I’ve never had that happen before! Weird that it just “happened” between one render and another!
At least I know it happens to other people!
Cheers,
October 9, 2018 at 7:05 am #207865
Andrew Giambrone
ParticipantInteresting! Your advice actually solved my problem! I think the next article in my blog will be about all these computer things. By the way, if you are interested – http://www.speckygeek.com/writing-research-papers-info-products/ you may check it out! I write about useful tips for students. Hope you’re gonna like it!
