Print an entire library price sheet
    • February 5, 2019 at 2:40 pm #225967
      Frank Camberos
      Does anyone know how to go about printing an entire catalog with prices for the sake of having it outside cap studio for reference?
      I remember a command over 10 years ago that when ran in AutoCAD, would insert every single part of that particular catalog. Not sure if that’s still possible today.
    • February 5, 2019 at 3:14 pm #225970
      2020
      Moved to Office for relevance.
      2020 Admin
    • February 8, 2019 at 8:37 pm #226422
      Travis Davies
      Where can I follow this?
    • February 11, 2019 at 10:26 am #226538
      Chad Bulthuis
      Thank you for taking part in our Community!
      The command you’re remembering is CAPXTESTBLOCKS.  If you type that command in AutoCAD with 2020 Cap loaded, you’ll be prompted to choose a catalog and set spacing values.  Click on the “Test” button and all of the items with graphics will be placed in the drawing.  (Items without graphics will be noted as text within the drawing.)  Do a Worksheet take-off of that drawing and you’ll get a worksheet with all of those items.  You can update against the catalog and turn on the “Catalog Location” column and sort by that column (or any other column that works for you).
      Remember that you’ll have every item that has a graphic, items that were noted as text in the drawing won’t be in the worksheet.
    • February 11, 2019 at 11:47 am #226593
      Frank Camberos
      Chad, that was it! Thank you!!
    • February 11, 2019 at 12:01 pm #226600
      2020
      Hi Travis,
      You should see a ‘Subscribe’ button at the top of the thread which will send you an email when ther’s an answer posted.
      Cheers,
      2020 Admin
