December 3, 2014 at 4:20 am #19900David GrantParticipant
I’ve used 20:20 for several years. I’ve found “Fusion” more intuitive than other 20:20 packages that I’ve used. Has anyone found problems with curved base end shapes? Those in the menus don’t appear to have the correct shapes. I guess it’s me (?)
December 4, 2014 at 9:17 am #20175James FerrisParticipant
Hi David,
Welcome to the community. Could I take an example from you im not sure I understand the query -
December 8, 2014 at 11:11 am #20309GrahamParticipant
I’ve had problems with them for a while David.
1. Auto – Plinth being set to far back or not inline.
Worktops the curve like the plinth not being correct. I have to change this manually whenever I design a plan with curves.
2. Curved doors not copying the shape of the door range chosen. This I find is prominent in most catalogues but it is most prominent in the Second Nature catalogue. Its a right pain. -
December 9, 2014 at 8:20 am #20312David GrantParticipant
Hello James, It could be I’m not looking for the 300x560mm curved shapes in the right catalogue. Although having said that, I looked through the whole of the base (without drawers) and through base unit others and still can find the right shape for a plan. Where do you look?
