How to create a wall in 2020 Fusion
    • November 4, 2014 at 8:55 am #19309
      Celeste Poirier
      Keymaster
      Adding walls to your design can be done in a variety of ways with 2020 Fusion:
      – For simple room outlines, 2020 Fusion’s ‘Wall Layout Wizard’ allows a designer to create rectangular, L-shaped or U-shaped wall layouts, as well as single wall or parallel wall configurations.
      – For more complex layouts, Fusion’s add palette has tools to add walls manually, allowing a designer to enter specific angles for millimetre perfect representation.
      – Finally, it is also possible to import a room layout received from an architect or other source to serve as a template when creating a room outline.
    • November 5, 2014 at 6:41 am #19361
      James Wilson
      It is also possible to add complex user defined walls within the ‘Wall Layout Wizard’.
The topic ‘How to create a wall in 2020 Fusion’ is closed to new replies.
