How do I change units?
    • April 3, 2015 at 11:30 am #26322
      suzana
      How do I change units? I need to change them from meters ti inches
    • April 6, 2015 at 8:52 pm #26388
      Re-install. Ridiculous but unfortunately the only way.
      I have no idea why 2020 Tech wrote Design this way as every other design program on the market allows you to change units in preferences. For some reason, even Catalogues are stored as either Metric or Imperial as well and converting from one to the other is laborious.
    • April 13, 2015 at 12:04 pm #26602
      If you want to change Units in version 10 you can change it from inches to metric in the Preferences menu under Display Tab schemes.  Any design you create after making the switch will be done in Millimeters.  If you only want to display a design you have already created in millimeters you can go to display settings for the design,  go to work area and change the unit of measurement there.
    • April 13, 2015 at 7:17 pm #26625
      Handy change – thanks Neil. Used to be that you had to re-install or odd things happened (V9)
