Hot From the Helpline: How do I save a default styles template?
    • May 28, 2015 at 10:46 am #29180
      Anthony Vicario
      To help you quickly add all relevant style options that you commonly use (Door finish, plinths, cornices, handles etc).
      – Within the style details screen (Default styles) select the styles as your normally would.
      – Make sure that you have “show catalogue options” available in the bottom left corner.
      – On the right beside Favorite Styles select “Save As Favorite” give your favorite a name.
      – You will now have style template (Theme) you can reuse for all future designs.
The topic ‘Hot From the Helpline: How do I save a default styles template?’ is closed to new replies.
