May 1, 2018 at 8:42 pm #184736
Joey Failma
ParticipantNew user here. I started with creating the client information first with no generated design. When I click on the Global Attributes, there are no items listed within the All Catalog category. Not sure if I did not something during the initial 2020 Design download. Any ideas or suggestions?
November 22, 2023 at 10:57 am #434825
Xzavier Cassin
ParticipantPossible cause of your problem is that you have not selected any catalogs to getting over it in your design. The Global Attributes are based on the catalogs that you choose to work with, and they show the available options and styles for the selected catalogs. If you have not selected any catalogs, the Global Attributes will be empty.
April 1, 2024 at 2:51 am #437775
enemy scuttle
ParticipantCreating customer information is necessary, you need to fill in enough information to be able to create the design. You need to select attributes for your catalog and complete the design to download it by happy wheels.
August 15, 2024 at 3:37 am #439358
Kent Erick
ParticipantIn order to be able to construct the design, it is required to generate client information. You need to fill in sufficient information about the customer. As a prerequisite for downloading your catalog, you will need to choose the qualities for it and finish the connections game design.
