Announcing 2020 Fusion v8!
    • September 10, 2020 at 3:51 am #296130
      Audrey Lenoir
      2020 is very pleased to announce the launch of 2020 Fusion v8. The latest version is packed with new features and enhancements that will make your working life easier!
      Deployment of Version 8 will commence shortly for all supported 2020 Fusion customers and will continue throughout the next couple of months. You will soon receive a pop-up in 2020 Fusion inviting you to update to the new version.
      Learn More
    • September 11, 2020 at 11:04 am #296396
      William Osborne
      Greta job!
    • October 15, 2020 at 10:04 am #301286
      darren mckeown
      Just recently download verion eight, was wondering if anyone else is having any problems with it. if i take items in from the browser most of the time they wont “load in” and i have to close the plan and open it up again for it to load the item in.  also items that are in the plans are reverting back to there orginial sizes ie cookers, stools etc.
      just wondering if this is an easy fix or is it a bug?
    • October 15, 2020 at 12:00 pm #301354
      Ryan Jackson
      Moderator
      Hi Darren,
      The re-sizing of cloud items is a know bug that we are working on at the moment. It should be fixed in the next Fusion update.
      With regards to the cloud items not loading, there is a temporary fix by clearing the cache.
      Please can you send me your Team Viewer details to fusionsupport@2020spaces.com so I can assist you?
      Kind Regards
    • June 23, 2022 at 3:37 am #371738
      Michael Donovan
      Hi Everyone, Is there a way to disable the corrective process that Fusion 8 does at the end of the rendering to smooth out the textures. It’s making a lot of my renderings look a bit smudged if that makes sense. I can post a before and after from the two different versions if you want to see an example. Thank you<!– [if gte mso 10]>
      <style>
      /* Style Definitions */<br />
      table.MsoNormalTable<br />
      {mso-style-name:”Table Normal”;<br />
      mso-tstyle-rowband-size:0;<br />
      mso-tstyle-colband-size:0;<br />
      mso-style-noshow:yes;<br />
      mso-style-priority:99;<br />
      mso-style-parent:””;<br />
      mso-padding-alt:0cm 5.4pt 0cm 5.4pt;<br />
      mso-para-margin:0cm;<br />
      mso-pagination:widow-orphan;<br />
      font-size:10.0pt;<br />
      font-family:”Times New Roman”,serif;}<br />
      </style><![endif]–>
      <!– [if gte mso 9]><xml>
      <w:WordDocument>
      <w:View>Normal</w:View>
      <w:Zoom>0</w:Zoom>
      <w:TrackMoves/>
      <w:TrackFormatting/>
      <w:PunctuationKerning/>
      <w:ValidateAgainstSchemas/>
      <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
      <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
      <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
      <w:DoNotPromoteQF/>
      <w:LidThemeOther>EN-US</w:LidThemeOther>
      <w:LidThemeAsian>X-NONE</w:LidThemeAsian>
      <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
      <w:Compatibility>
      <w:BreakWrappedTables/>
      <w:SnapToGridInCell/>
      <w:WrapTextWithPunct/>
      <w:UseAsianBreakRules/>
      <w:DontGrowAutofit/>
      <w:SplitPgBreakAndParaMark/>
      <w:EnableOpenTypeKerning/>
      <w:DontFlipMirrorIndents/>
      <w:OverrideTableStyleHps/>
      </w:Compatibility>
      <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
      <m:mathPr>
      <m:mathFont m:val=”Cambria Math”/>
      <m:brkBin m:val=”before”/>
      <m:brkBinSub m:val=”--“/>
      <m:smallFrac m:val=”off”/>
      <m:dispDef/>
      <m:lMargin m:val=”0″/>
      <m:rMargin m:val=”0″/>
      <m:defJc m:val=”centerGroup”/>
      <m:wrapIndent m:val=”1440″/>
      <m:intLim m:val=”subSup”/>
      <m:naryLim m:val=”undOvr”/>
      </m:mathPr></w:WordDocument>
      </xml><![endif]–>
    • June 27, 2022 at 5:30 am #372015
      Ryan Jackson
      Moderator
      Hi Michael,
      The smoothing of the textures is part of the process that’s built into the rendering engine so this can’t be managed I’m afraid.
      I can’t see the issue in the images you’ve sent as they aren’t showing. Please feel free to email them to fusionsupport@2020spaces.com or call in on 01233 635 533 and I will take a look.
      Kind Regards
